Hey guys,
I want to catch a mistake concerning the mesh. when this mistake is occuring, the user should be able to fix the mesh.
During a while loop i have sometimes an error in the command *plotnodelist, because it needs the inputs "results of a analysis" and "nodes id".
Sometimes the analysis fails and *plotnodelist leads to a break down of Hyperworks because of the missing results.
Here is the relevant part of my code:
while {} {......
if { [catch {*plotnodelist 1}] } {
   puts "analysis failed "
    break
} else {
*plotnodelist 1
Kind regards
Simon
The failure information is on the lower left corner.
If this failure occurs, HyperMesh shows no reaction and has to be closed and opened every time.
I want to catch this failure and stop the loop if the failure occurs.
After this i want to correct the mesh in HyperMesh and start another iteration.
I see two things you can do:
1. Identify the error reading the result's file and act accordingly;
2. Identify the root cause from the meshing process and act from there.
Do you know which mesh issue is causing this problem?
Thanks for your efforts!
1. I'm executing a solver at first and load the results afterwards.
But sometimes the solver failed because the meshed is too bad, so no result file is
written. The command *plotnodelist needs the results file and fails if it's not existing.
--> HyperWorks closes
2.  meshing problem is non-correctable, because two 2d mesh edges are running into each other
during thermal expansion and the mesh overlaps. The solver fails in the next step in a static analysis (--> 1)
The overlapping is shown in the picture.
The skript is running for many iteration without problems, but after some iteration the described problem occurs and HyperWorks crashes.
I want so improve the mesh after it fails and start the programm again.
There must be a mistake in the code of catching the problem.
For the sake of completeness the part before the command '*plotnodelist
# executing the solver
exec $batch -analysis "$path/${name}.fem"
hm_answernext yes
*analysisfileset "$path/${name}.res"
#make a contour plot
*setgeomrefinelevel 1
*drawlistresetstyle
*setcuttingplanesbase 0 29.3749355 7.5
*clipboundaryelements 1
*inputsimulation "SUB1 - Statische Analyse      " "Von Mises Stress"
*contourplot "" 0 0 0 0 1 0 0 0 "magnitude" 1 0 0
#select the component nodes and plot the results
*createmark nodes 1 "by comp name" Randschicht
*createlist nodes 1 {*}[hm_getmark nodes 1]
set NodeList [hm_getlist nodes 1]
    break
} else {
*plotnodelist 1
