Dung the most handsome man
[SOLVED] Error: vp_parasolidmesh.exe has stopped working
This is most likely due to the same kind of problems you have with your other meshing error and I would recommend the same methodology:
  1. Run Part only for solidification
  2. Add cores and run for solidification
  3. Add risers and run for solidification
  4. Add sleeves and run for solidification
  5. Add chillers and run for solidification
  6. Add Running systems and run for solidification
  7. Add Gate and run for filling
By going progressively you can find out which component is creating the issue. Then the issue can come from either bad geometry itself or interface between components i.e. small gaps between components that cause the mesh to fail for the mold.
Thanks,
Matthieu
