Sign in to follow this
SimSolid Member
Boundary conditions
What do you mean by “posed”. In static analysis you need to remove rigid body motion of the structure. There must be sufficient boundary constraints to do this. “Immovable” removes all motions, “Sliding” removes normal motion, but allows movement along a face (tangitial directions), etc.
For a structura resting on ground, the easiest method is to just pick the surfaces that touch the ground and set them to immovable. If you want a “soft” connection, you may consider using an spring support (sometimes called and “elastic foundation”) constraint as well.
