Sign in to follow this
SimSolid Member
analysis possibility for silicone gasket of a pasteurization tank
You can do the following:
– this problem is a 2D or axis-symmetric problem. You can create a slice of the geometry and apply sliding to the sides of the slice
– the lid is fixed, the ridge is in contact with the gasket. Apply vertical displacement to the ridge. The displacement is equal to the gap between spacer and the lid.
– apply NL material to the gasket
– watch the reaction force vs displacement at the ridge bottom
