Turbokraken
3D Solid Material oriantation for MAT9ORT
Hi Everyone,
I started playing with MAT9ORT cards to gain an ansight on how to work with this material type. However for this, I'll need to assign a normal direction to my solid, but I am struggling to do so. I am using Analysis -> System -> Material orientation and try to align it with a vector / y-axis, but it does not work. It just shows like this:
Please refer to the picture for details.
How would I prepare my solid for a MAT9ORT use?
Best Regards,
Lennart
Hi Rahul,
this unfortunately did not help it. I am using this dialog box to create a material orientation, but when I click apply nothing happens.
EDIT:
I select all Elements.
I use orientationmethod by curve
I choose a line
I click apply
and chaos ensues, just like before.
EDIT2:
I have created a coordinate system uznnd tried to reference the vector using its 2-axis (y) an it just creates the same mess, although i looks differently.
Okay, it kind of got solved.
For everyone who has thr same issue.
The System or the Mateial orientation dialog does NOT work for this. (2017.2)
However you can create a coordinate system und put it into the property as CORDM. Select "USER" and choose the coordinate system. The materila will orient itself around the X-axis.
Rahul R and MartinaC like this
