Sai Vignesh
Modal effective mass
Kindly find the attached out file
In effective modal mass i am getting my total mass  in translation direction
Why not in rotation of X direction?
Is the unit different when it comes to translation and rotation ?
Thanks for your help
3 hours ago, Rahul R said:
The Modal Effective mass in the Trans X, Y and Z directions and Rotational X, Y and Z direction have the same units.
Thanks for reply but in total mass in rotational directions why it is not equal to total mass? in translation i get my total mass equal to system mass but in rotational it shows 250kg which is more than my over all system mass
The Modal Effective Mass is a measure of how much mass is associated with each mode.So for the more prominent mode you will get more mass.
Thanks for the answer Rahul
Yet still why do i see high mass value in rotation direction
Mass value in rotation direction is higher than my system mass
kindly clarify
I see you have requested only first two modes, which might be missing critical data and under predicting response of the system.I request you to run with ND as 25 modes in EIGRL card and then evaluate the response in out file.
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
