mvass
excel file contents to Import laminate
Hello all,
I had a look in the forum but I could locate anything specifying the contents or the form of the excel file required in order to import (not export!) the ply layup when creating a laminate in Hypermesh. Could you please provide an example file?
Thank you.
Dear Rahul,
thank you for your reply and the attached file. However I was looking for the excel file format in order to import the plies during a "laminate" creation (PLY based modeling).
See attached picture.
Thank you.
I've found the answer myself:
Refer to help: Create/Edit Laminate Dialog
Select Import from Excel (as seen in the above picture), then select .csv file. Select your file (must be comma separated) and open. I have attached an example .csv file (Hypermesh format) for your convenience.
import.csv
Rahul R likes this
