Sign in to follow this
cjc
Mr
Hi all,
The Acusolve 2018 Release Notes announced the added Multiphase  capability which allows more than 2 fields unlike the previous versions which allowed only 2 fields.
I have been trying to use this feature but in Auto Solution Strategy there are only Field 1 and Field 2 visible, regardless what one defines in Multiphase Parameters (three Fields and their associated Field Interaction Models and Multiphase Models).
Has anyone come across this issue?
Best regards,
cjc
From the Command Reference Manual, " An unlimited number of dispersed fields can be modeled with one carrier field using multi_field=algebraic_eulerian."  In other words, the 'multiple fields' option is only available when using algebraic_eulerian.  There can then be multiple dispersed fields modeled within one carrier field.  This appears to be an algebraic model, not what you would have with levelset.  Levelset is still limited to two immiscible fluids.
