sanket_patil
search a componet using loop
Hi All,
I have changed Id of a component in hypermesh  and i have a .csv file which contains component's Ids and their thicknesses. Now i want to search component,s id in .csv file and corrosponding thickness value from csv.
Can anyone tell me how to do this using tcl?
Thanks,
Sanket
Hi
Example csv file:
CompId,Thickness
1001,1.0
1002,1.2
2001,2.0
2002,2.2
2004,2.5
This is a sample code
set myfile c:/afile.csv
set fpt [open $myfile]
set cont [string map {, " " \n " "} [read $fpt]]
close $fpt
set MyCompId 2002
set Thickness [dict get $cont $MyCompId]
vipin likes this
@sanket_patil
Tinh is already gave you the good example:-)
-Here is my example-
# Auto property creation #
*evaltclscript "AutoPropertyCreate.tcl" 0;
*evaltclstring "::autoproperty::Main" 0;
# Thickness update from CSV #
set ft {{"CSV Files" .csv} {"All Files" *}};
set fn [tk_getOpenFile -filetypes $ft];
set fh [open $fn r];
while {![eof $fh]} {
 gets $fh line;
 lassign [split $line ,] cid T;
 if {[hm_entityinfo exist comps $cid -byid] == "1"} {
  set pid [hm_getvalue comps id=$cid dataname=propertyid];
  *setvalue props id=$pid PSHELL_T=$T;
close $fh;
If you are not using PSHELL card, you have to change the attribute name.
vipin likes this
