Minoru Yubuchi
Brake Modelica Block in Activate
Dear all,
1) In the Activate on-line help, ports of Brake Modelica block are described as:
f_normalized.
Support/housing of component
support.
Optional port to which dissipated losses are transported in form of heat
heatPort.
Normalized force signal 0..1 (normal force = fn_max*f_normalized; brake is active if > 0)
Is thi correct? It should be:
f_normalized.
support.
heatPort.
Correct?
2) I turned on the support port and attached a spring/damper block to it, but the model issued an error. Please let me know how to use the port.
I attached the model. Please let me know how to modify it.
Minoru Yubuchi
Brake03.scm
Yubuchi-san,
ad 1) I think you are right. Somehow the explanatory texts have shifted. The Modelica source code contains e. g.
Modelica.Blocks.Interfaces.RealInput f_normalized "Normalized force signal 0..1 (normal force = fn_max*f_normalized; brake is active if > 0)"
ad 2) Your model should work, but OpenModelica also has its numerical difficulties with it. If you add a mass at support port, the model works fine (see Brake04.scm).
Best regards,
Ronald
Brake04.scm
