from
OS-T: 1325 Random Response Analysis of a Flat Plate:
1.From the Analysis page, click control cards.
2.Go to the GLOBAL_CASE_CONTROL panel.
3.Check the box in front of RANDOM, double-click the highlighted ID button and select load collector with RANDPS card image.
4.Return to Control Cards and click GLOBAL_OUTPUT_REQUEST.
5.Check the box for STRESS to activate the card edit panel.
6.Select OUTPUT2 as the FORMAT, PSDF under RANDOM, and YES under OPTION.
RMS and PSDF stress are output to a .op2 file
OS-T_ 1325 Random Response Analysis of a Flat Plate.pdf
Sign in to follow this
