Sign in to follow this
InspireUser
Problem in FEA: Column is not buckling?
Hi all,
I have a column in my model and it is not buckling in the FEA analysis, rather getting compressed. The load is being applied uniaxially with respect to the column.
Is there a way I can make the column buckle? In ABAQUS, we introduce imperfection in the column by deviating the geometry by a little bit based on buckling modes (scaled by 0.5 to 1%). I was wondering if we can do the same in Inspire since there is an option for buckling mode calculation during FE analysis.
you can get a column to buckle by introducing imperfections in:
-geometry
-loads (small off-axis load component)
However, I don't think non-linear buckling analysis can be done in Inspire because it uses a linear solver. It can be done using Optistruct or Radioss.
Actually, linear buckling analysis does not require imperfections, because a small displacement of a perturbed shape is assumed in each element that induces a stress-dependent stiffening effect:
https://www.digitalengineering247.com/article/linear-and-nonlinear-buckling-in-fea/
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
