Andreabb
Meshing complex STL file
I have a problem with a complex component (STL file) that contains different dimension of triangles because there are lattice regions and massive regions. Unfortunatley, i try to use the "shrink wrap" command, but this creates or little tretra-elements (and after the analysis is very expensive) or big elements(in this case i lose the details of reticular part). How can i do?
I try to convert all the STL file in surfaces using "From FEA" in surface, but the result is a very irregular surface with a lot of hole.
Thanks
Unfortunately, this way creates uniform mesh (tetra elements similar in dimension, i try with 0.01 minimum tet collapse) and collapse the details of the lattice region. Do you know other solutions?
Hi Pooja S,
My structure is more complex. I create two different mesh with "shrink wrapand this is a part of my model. There are two components: lattice part (that needs precise mesh) and massive part (that needs rought mesh). How  can i merge the two part?
meshing.hm
Thanks Pooja S,
I make the tria-mesh on the surfaces(2d) but  after this the solid mesh (tetramesh) isn't available because "the mesh is not enclosed".
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
