nara4838
Error % keeps increasing
there are intersections in the "self dummy" contact- all intersections and penetrations should be removed before running the model.
Check and remove manually or automatically any initial intersections and penetration in your model by using Tool>> Penetration or in Hypercrash by Quality>>Check all solver interfaces. Please go through HM-3320: Penetration tutorial in Help Menu which shows fixing penetrations.
9afbe617ffc32a67b5e54a3a9d8a484615022f79.jpg?image_play_button_size=2x&image_crop_resized=960x515&image_play_button=1&image_play_button_color=54bbffe0
New Feature in HW 2017 - Collision Detection Tool - Altair University
Try to run the attached solver deck. There are some other modeling issues remaining.
seatbelt_0000.rad
pohan likes this
Negative Energy Error is dissipated from the system with:
-plastic deformation
-hourglass energy
-contact with friction
-contact intersection & penetration
Energy error.pdf
Open the run_nameT01 time history file in Hypergraph and plot the Global variable>Internal, Kinetic, Contact, Hourglass, Total energy.
See attached documents for details (from Introduction to Explicit Analysis using RADIOSS – A Study Guide)
Crash_Analysis_with_RADIOSS.pdf
It gives me an error of Mass error Limit reached.
205000  0.1025      0.5000E-06 NODE       30658  99.9%   3867.      0.1269E+06  0.2799E+05 -0.1302E+05   71.74
     ANIMATION FILE: seatbelt_negative_energyA207 WRITTEN
206000  0.1030      0.5000E-06 NODE       30658  99.9%   3967.      0.1269E+06  0.2797E+05 -0.1297E+05   71.74
     ANIMATION FILE: seatbelt_negative_energyA208 WRITTEN
207000  0.1035      0.5003E-06 NODE       31463  99.9%   4056.      0.1269E+06  0.2795E+05 -0.1292E+05   71.74
     ANIMATION FILE: seatbelt_negative_energyA209 WRITTEN
208000  0.1040      0.5001E-06 NODE       31463  99.9%   4148.      0.1268E+06  0.2793E+05 -0.1287E+05   71.74
 WARNING INTERFACE         10
 NODE      21756 DE-ACTIVATED FROM INTERFACE
MESSAGE ID :          207
 ** RUN KILLED : TOTAL MASS ERROR LIMIT REACHED
