Dung the most handsome man
Measure the porosity size
I did a tutorial in Inspire cast, the porosity result has shown the areas that the ratio of voids to solid areas is greater or equal than to the specified value. And i don't know how to measure the size of the porosity of each value. So, how can i measure the size?
Thanks.
"Porosity" result shows the macro porosity as a percentage
"Total shrinkage volume" shows the macro porosity as a volumetric value.
"Micro Porosity" shows micro porosity as a percentage
"Niyama" shows micro porosity as ((C*s)**0.5/mm)
Junta likes this
On 2/15/2019 at 9:29 PM, Pau said:
Hello guys,
I have a question: the porosity result is in percentage: the ratio of voids to solid areas.
So what is the Area in calculation? Is it the tetra element volume?
Thanks!
