Minoru Yubuchi
MoCustomComponent block
Dear Experts,
I built a simple model that contains a MoCustomComponent block that represent a mass (see attached Activate model). The script in the block is just copied from Mass modelica block.
The model issued the error (see the picture attched). What should I modify?
Thanks,
Minoru Yubuchi
Samples_Modelica.scm
Hello Minoru,
Your modelica Code should be something like that:
model C_Mass "Sliding mass with inertia"
    parameter Modelica.SIunits.Mass m(min = 0, start = 1) "Mass of the sliding mass";
    extends Modelica.Mechanics.Translational.Interfaces.PartialRigid(L = 0, s(start = 0));
    Modelica.SIunits.Velocity v(start = 0) "Absolute velocity of component";
    Modelica.SIunits.Acceleration a(start = 0) "Absolute acceleration of component";
equation
    m * a = flange_a.f + flange_b.f;
    a = der(v);
    v = der(s);
end C_Mass;
Note that I've removed the stateselect since it is not a block parameter, you can put it back if needed.
Thanks
Fady
Fady,
Thank you so much!
Let me ask you one question. The original script of Modelica Mass block in Activate has a line "parameter SI.Mass m(....", not "parameter Modelica.SIunits.Mass m(...." as you mentioned.
Why does the original script not issue any errors?
Minoru Yubuchi
At the top of package Translational SI is defined as placeholder for Modelica.SIunits.
import SI = Modelica.SIunits;
Everywhere else in this file you can use SI instead of Modelica.SIunits.
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
