hello,
i am new to make scripts. i am trying to do a script to delete empty assemblies and sub assemblies in one action. i need a loop format of script to do this. but i dont know the structure. please help me out.
Will tell the logic, try to do yourself and let us know if you still need help.
EntityPreviewEmpty will check the empty assemblies in your model. Use this API and while loop to check and delete the empty assemblies
use deletemark to delete the entities.
Check this to understand how while loop works https://www.tutorialspoint.com/tcl-tk/tcl_while_loop.htm
llyle and MEIYARASU19 like this
*EntityPreviewEmpty 1
set d [hm_getmarkentitytypes 1];
hm_createmark 1 $d;
#while loop execution
while { $d == 1 } {
   puts $d
   incr d
*deletemark $d
i have tried with my knowledge, please let me know your corrections.
thanks in advance.
Here's the script found on Altair site:
#This script deletes assemblies recursively, optionally comps will be deleted
# steenbock@altair.de, 20141008
# V. 01
proc run {} {
	*clearmarkall 1
	*createmarkpanel assems 1 "select assems 2 delete"
	#delete comps or not
	set answer [tk_dialog .owd "Selected Assems: [hm_getmark assems 1]" "Delete Components in Assems?" "question" 0 "No" "Yes" "Cancel"]
	switch $answer {
		0 {set delComps 0}
		1 {set delComps 1}
		2 {tk_messageBox -message "Misson abort!" -type ok -icon warning; return;}
	# loop whole assem tree
	foreach ass [hm_getmark assems 1] {
		deleteSubAssems $ass $delComps
	*clearmarkall 1
proc deleteSubAssems {assem delComps} {
	set output 1
	if {[hm_entityinfo exist assem $assem] == 1} {
		set sub_ass [hm_getentityarray assemblies $assem assemblies]
		# part where comps will be deleted
		if {$delComps != 0} {
			set sub_comps [hm_getentityarray assemblies $assem components]
			if {[llength $sub_comps] > 0} {
				eval *createmark comps 1 $sub_comps
				if {$output ==1} {puts "\t\tdelete comps: $sub_comps"}
				*deletemark comps 1
		# delete assem
		*createmark assems 1 $assem
		if {$output==1} {puts "\tdelete assem id=$assem ([hm_getentityvalue assemblies $assem name 1])"}
		*deletemark assems 1
		if {[llength $sub_ass] > 0} {
			foreach a $sub_ass {
				deleteSubAssems $a $delComps
run
# V. 01
proc run {} {
	*clearmarkall 1
	switch $answer {
		0 {set delComps 0}
		1 {set delComps 1}
	*clearmarkall 1
	set output 1
				*deletemark comps 1
		# delete assem
run
this script is not working
For future reference, I was able to do using below:
	set str_flag 1
	while {$str_flag} {
		*EntityPreviewEmpty assem 1
		if {[hm_marklength assem 1]} {
		} else {
			set str_flag 0;
	set str_flag 1
	while {$str_flag} {
		} else {
			set str_flag 0;
I am run this script but error is entity is not found why?
On 2/27/2019 at 8:18 AM, tinh said:
While {*EntityPreview.. ; hm_marklength assems 1}  {*deletemark assems 1}
hm_createmark 1 $d;
*deletemark $d
this is also not work
