mkress
Solver-Error
Hi Guys,
i get a solver error that i don´t understand.
Does anyone knows the reason for this error? I think it is a Problem with a function...
I solve a multiphase Problem. Perhaps it is the Water volume fraction scipt.
The script is:
value=0
if (z<0.0):value=1
The script describes that everything under the z-Level "0" should be water. But i can´t see any mistake here...
(Z-Level=0 is in the middle of the geometry)
Thank you very much!
Hallo ydigit,
thank you for your reply. You are rigth it wasn´t the script.
I have found the problem, it was the mesh. I had to much bad elements inside.
What are your settings under "check Elements" for CFD Surface meshing?
Could you tell me what points i should consider for CFD-meshing?
Generally I try to avoid elements with small angles <10°. Also check for any really small elements (cannot give an absolute value though).
Say you average element size is ~10, then search for elements <1 to see which are smallest (sliver) elements. These are typically going to create big trouble for boundary layer meshing.
In a way both are related issues. Small angles lead to small elements.
mkress likes this
