MOHAMMED ABDULLA T
hm_calldisplaypanel while *createmarkpanel operation
Dear Members,
I am trying to mark some elements by the option *createmarkpanel elems 1. But sometimes the elements I wanted to select maybe below a component. If that is the case while manual operation I press the "D" button and hide that component and select below elements . But since I am in an operation of *createmarkpanel I am not able to call hm_calldisplaypanel operation in between . Is there any way to hide component while *createmarkpanel option.
Thanks
Mohammed
Cannot call panels while *createmarkpanel was there because hm is in function_lock mode
But you can turn off comps on model browser
Another way: view elems in wire-frame mode and sweep mouse over elem's centroid (displayed as a dot) => suitable with single selection.
Or you can sweep mouse over both upper and lower comps and then click elems>by collector to subtract the upper elems.
