migid
Composite Using Solid Elements
I built up a Tension analysis wit a coupon speciment.
Material: LAW12
Property: P6_SOL_ORTH
I want to set up the materialorientation. I tried to assign the nodes to a coordynatesystem, which is rotated by 45 grad and tried to set the parameter "Psi" on 45 Degree, but neither of them worked. Can you please help me by building up a laminate?
## Orthotropic Solid Property Set (pid 6)
/PROP/SOL_ORTH/1
solids
        17         2                   3                                       2
        1
                45.0
