Sign in to follow this
felix
how can i import DXF.datei? how can i chose the option?
To import the DXF file in Flux:
  • Flux 2D
    • Open a new Flux project
    • From the tab select project
    • Select import >> import geometry >> import geometry form a DXF file
  • Flux 3D
      About the import options, if your DXF file contains only faces you need to select import free faces form the entities.
      If the problem persist, can you send as your DXF file.
      Best regards.
