Sign in to follow this
sanket_patil
Drag nodes from free edges
There is not a direct way.
You have to detect 4 sides of the square and then select 2 opposite sides. I think you are beginner so it is so tough with you.
And you will ask how to detect...
You must compare angle between each pair of edges and record the node as corner if angle is not 180D
And you will ask how to compare angle...
You must make some loops to calculate angles, sort to see which ones not 180D
And you will ask how to make a loop...
:rolleyes:
You should learn hypermesh and basic tcl first. Then write some sample codes, see how it works, divide your work into small tasks, write tcl procs for each task, combine them to form a full program.
And, you should not learn tcl right if you are not good at hypermesh yet. Tcl macro simulates how you act with HM.
Livil Lyle likes this
