AV1
Exporting colors from one flux project to another
Is there a way to export the custom defined colors from one Flux2D file to another. This would save time by not requiring to re-do it again in a new project.
You can do it by following the next steps:
 - open Flux project
 - in the tree on the left click on [Tools] [Colors] (in fact on the cross in front of the menu) to open the menu with colors
 - click on one color (or more than one, using the CTRL keyboard function to add colors in the same list) (I would recommend to select only NEW colors)
 - then right click
 - then select [Python export]
 - give a name inthe [pyton file] part, for instance colors
 - click on the [OK] button
 - close your current Flux project
 - open the Flux project where you want to import your new colors
 - select the menu [Project] [Command file] [execute in direct mode]
 - select the python file you have generated (for instance colors.py)
 - it will generate your new colors (note: there will be an error if the name of the color is already defined)
I hope it will work on your side.
Another way to do it one by one is the following:
 - select your color in the tree on the left
 - right click
 - selelct [Display PyFlux command]
 - it will display the command to generate the color in the [output] window
 - copy the command (for instance
Color(name='CYAN_1',
      code=[0,
            0,
            255])
 - then open your second Flux project where you want to create this color
 - paste the lines in the [PyFlux Command] window
 - click on the green arrow on the left
 - it will execute the pyFlux command, and generate this color (without error if the name does not exist yet)
I hope it will help.
regards
Patrick
AV1 likes this
