felix
there is no air zone around mechanical set : ROTOR
Unable to calculate torque : there is no air zone around
Hi Rahul Ponginan,
the error is,
ROTOR: This mechanical set is not completely characterized.
Please, modifiy the type of this mechanical set.
External arc axes and the rotation axis
of the mechanical set ROTOR are different.
The mechanical set rotation is impossible
The sliding lines of the mechanical set ROTOR must form a circle
Concerned line(s) : 6 7 9 10 11 12 13 14
End of physical check.
   checkPhysic executed
thanks
Ming
