Guy01
Show elements in a pre-defined set in hw
Hello
Can anyone help me to do a "isolate only" type of operation by command?
I would like to display results on a set defined in hyperview.
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page1 [proj GetActivePage ]
page1 GetWindowHandle win1 [page1 GetActiveWindow]
win1 SetClientType "Animation"
win1 GetClientHandle po1
po1 GetModelHandle mo1 [po1 GetActiveModel ]
mo1 GetSelectionSetList # i can see the available set list with this command
I cant find the way to select only a particular set (knowing its name or id).
Thanks in advance for the help
Hello again
I never undertood when experts like you dont want to answer questions. Is it that the question is too hard to answer or too dumb?
Or is it such a secret that you don't want to reveal it?
Sometimes a simple answer like "NO we cant do that" is sufficient and it is confusing to see no reply.
Anyways you guys provided help till now so thanks for that. I will surely find myself answer for this soon.
Hi Roche,
You can try the below commands to Set you need:
 set setHandle [$modelHandle GetSelectionSetHandle setH1 "Set $id"]
 set nameSet [setH1 GetLabel]
# Can also be:
 set setHandle [$modelHandle GetSelectionSetHandle setH2 "User_Set $id"]
 set nameSet [setH2 GetLabel]
# User_Set or Set are called pool can be found through GetPoolList
# Refer documentation for more info.
tinh, Guy01 and vipin like this
On 3/9/2019 at 5:59 PM, Roche said:
Hello again
I don't have an answer but I will not say no we can't do because someone else could have right answer, just he is busy. ^_^
Guy01 likes this
