BG913
Selection of components as per user
Is there a way to select components in the order the user selects ?? I checked for *createlistpanel but it isn't applicable for components, and hm_getmark always gives a result of a list which is ascending order only.
Why do you need that?
A workaround is : select elem list, and then retrieve component list that store them.
Directly, I think we can hook a callback with event graphic_selection_changes
Pandurang likes this
Actually for this code I really want it as a component selection rather than element. That way the user knows the entire range of selection he/she is making. Like as much as possible I want to avoid the element selection as it would be not as appealing to the user.
And I'm sorry, I don't know much about graphic selection changes, haven't explored those options.
please Try this:
variable list1
proc framework args \
    *createmarkpanel comps 1 "Please select the components ";
    hm_framework registerproc getorderedcomps graphics_selection_changed;
   *clearmark comps 1;
proc getorderedcomps args \
    variable list1;
    lappend list1 [noIntersect;];
proc noIntersect args \
    variable list1;
    foreach item [hm_getmark comps 1] \
        if {$item in $list1} \
            continue;
        } else {set comp $item};
    return $comp
framework
puts $list1
Livil Lyle and tinh like this
@BG913
Even if deselect component this will take care of it.. Thanks To @tinh for suggestion...
Please try this updated one:
variable list1
    *createmarkpanel comps 1 " ";
    variable list1;
    set value [noIntersect]
    if {$value != ""} \
        lappend list1 $value ;
    variable list1;
    set marklist [hm_getmark comps 1];
    foreach item $marklist \
            continue;
    if {[info exist comp]} \
        return $comp
    } else \
        foreach item $list1 \
        if {$item in $marklist} \
            continue;
        } else \
            set list1 [lremove $list1 $item]
framework
puts $list1
Edited by Pandurang
