Sign in to follow this
felix
physical problem after check
External arc axes and the rotation axis
of the mechanical set MS_ROTOR are different.
The mechanical set rotation is impossible
ICRTYE   => No type for a stranded coil
ICRTYE   => failed
ICRIT2   => Unknown type of stranded coil
ICRIT2   => Failed
ICZICT   => Failed
UC_VRBOB => Failed
UC_VCI   => Failed
FL6VPB   => Failed ...
FL6VPB_1 => Failed ...
executeAlgo_c => failed
i try to build a modell of a reluktanz motor. and after physical check, i got this error.
Best regards.
Ming
