rk2
hm_measureshortestdistance not working properly
                    image.png.aabafc49bd9f6f99cb524bdc5e2f1f30.png                            image.png.1e3de18edb803d25e6c85801c529c879.png
All the brown color elems are 3d elements in the collector solidmap while the green color elems are 2d elems in collector auto1.
I execute the following command
*createmark elems 1 599
*createmark elems 2 "by comp name" auto1
hm_measureshortestdistance elems 1 0 elems 2 0 0
it returns->  0 0 0 0 599 0 0 0 1 0 0 0
but as we can see the distance between elem id 599 and elem id 1 is not 0.and elem id 1 is not the nearest elem to 599 among all other elems of auto1.
Can somebody explain this ?
I got the ans, elem is not a valid entity type for this type, the Valid values are nodes, points, lines, surfaces and solids.Apart from this is there any api which can do the task which I intend to do ?
How about this:
*createmark nodes 1 "by elem" 599
*createmark nodes 2 "by comp name" auto1
set N2 [lindex [hm_measureshortestdistance nodes 1 0 nodes 2 0 0] end-3]
*createmark elems 1 "by node" $N2
puts "closest elems: [hm_getmark elems 1]"
You can use hm_entityinfo centroid elems
to get centroid of e599 and the closest elems then compare which one is closer to e599 => decide that is closest.
hello Tinh
hm_measureshortestdistance nodes 1 0 nodes 2 0 0 is giving "expected integer but got "0 " error ..
a relevant command you should refer:
hwat::utils::GetClosestElement
in package hwat
Refer HW Help Home> Hyperworks Tools > Hyperworks Automation Toolkit
rk2 likes this
hwat::utils::GetClosestElement first three arguments are x y z coordinates but the last argument is assembly name. This argument is not working if I give the collector name as here "auto1"
put that collector (comp) in an assembly,  and use the assembly name as argument
yes putting that component in a different assembly works. Thanks for the solution . And I tried the hm_measureshortestdistance on a different computer but its giving the same error
