uri
Filters Position ICAST 2019.1
Hello to all
When inserting filters, should they be inserted:
Inside the housing (as above)?
Exactly with hosing walls?
Outside housing walls as below?
Best Regards
Uri Inbar
Engineering Dep.
David Quality Castings Ltd.
Tel: 972-3-9024415 Mobile: 972-52-5261177
Fax: 972-3-9024390
E-mail: uri.i@tirosh-casting.com
Web Site: http://www.tirosh-casting.com
Uri,
If you import your filter from the CAD, you can use its real shape:
  • Inside the housing (diameter filter < diameter channel): not the best solution because the metal can by-pass the filter
  • Exactly with hosing walls (diameter filter = diameter channel): the best solution
  • Outside housing walls (diameter filter > diameter channel): the metal is slowed down as the filter is filled first and once it is saturated the metal can flow.
I hope this helps.
Matthieu
