Gopi T
Renumbering issue in Hypermesh !
Hi experts,
I am facing some issues with node/element numbering in Hypermesh14.0. when I check the min/max node/element range in renumbering panel its showing whatever I renumbered before. but when I export(displayed) into abaqus inp file, getting different node/element numbering. any solution for this?
thank you
Do you have includes in your model? Maybe, it wrote IDs as XML format in inp file. From v14, ID numbering rule is changed.
Try removing checkbox "ID Rules" in export tab.
hi tinh,
thanks for your reply. I did not find "ID Rules" check box in export tab. can show me with picture?
2 minutes ago, Pooja S said:
Hi Gopi T
ID Rules is encircled in the below image
ok, thanks
I am using v14.0. may be your hm is new version.
thanks
Hi Gopi
This option is present even in 14 version and
this option is applicable only if you have some includes files in your model
for model with out includes working fine at my end ,  please do share the model if possible
