Marcus Chang
something wrong in far field pattern result when using near field source
Hi @Marcus Chang,
20 lambda is just a rough estimation for RL-GO, it always depends on the model.
Your model seems ideal for PO or LE-PO (only one interaction on the reflector). The solution should be quite accurate. RL-GO would work but it will require much more time because the near field source will be transformed into a spherical modes source first (and same for the Rx antenna).
Just apply PO (full ray tracing) to the reflector face and you should be good. Also compare with LE-PO (full ray tracing).
