xiaoming
Geometry check in solid model
Hi,Thanks to all of you for your valuable time and efforts putting in helping others.There are some geometry errors in my solid model. I can only find some ways to detect and repair topology to do some geometry cleanup.
The case is that there is no topology errors in my model, but other errors such as one surface penetrating another surface but maintaining correct topology(see figure1). I want to kown whether there are some ways to detect those errors.
Thank you very much!!!
Hello xiaoming,
On the geometry level, you can try using the following option:
If you are already creating the mesh from these surfaces, you can use the penetration tool.
Hope this helps.
Best regards.
25 minutes ago, Jeffersondhv said:
Hello xiaoming,
Hope this helps.
Best regards.
Thank you very mush!I use it to check a solid.It shows Intersections found.But how can i see the intersection facets?
M.karthickraja and llyle like this
