Vikas Kumar
To get node id attached to a system through CELAS2 Element
Hi all,
I wants to get system which is attached to "CELAS2" element.
                                            or
Node we can get which is attached to "CELAS2" element. From here How we can identify that system is also attached to that node.
Is there any way to know node id from which a system is attached or can we identify whether a system is attached to a "CELAS2" element.
I am using this code to get node id of "origin" but it is showing zero.
# With system id
set x [hm_getvalue systems id=52 dataname=originnodeid] ;  # returning 0
# With system collector showing 0 attribute
set x [hm_getvalue systemcols id=1 dataname=attributesmax] ;
we can get node id by using Xref entities in HM for reference i am keeping image:-
@tinh or @Livil Lyle help asap.
Best Regards,
Vikas Kumar
Thanks livil,
This is helpful. I never tried in reverse as you have mentioned.
And how we can review system as shown in image. If we know system id.
@Livil Lyle please suggest.
I tried below code but it is not helpful.
*createmark systems 1 "all"
set sysID [hm_getmark systems 1]
*clearmarkall 1
foreach sys $sysID {
    *createmark systems 1 "by id" $sysID
    *showentitybymark 1 1 2
    *reviewentity systems "by id" $sys 3 1 0
    hm_redraw
    tk_messageBox -message "see is it ok"
    *resetreview
Best Regards,
Vikas Kumar
1 hour ago, Livil Lyle said:
Hi Vikas,
Have you tried:
set systemid [hm_getvalue nodes id=$nodeID1 dataname=outputsystemid];
else please share a simple model with that element and system.
Hi Livil,
Can we get system "reference and displacement" node by using tcl\tk script.
It's very urgent.
@Livil Lyle @tinh
Best Regards,
Vikas Kumar
3 hours ago, Vikas Kumar said:
Hi VIpin,
But in this method how to check which is assigned node and which one is referenced node.
It is returning both.
Vikas Kumar
As Vipin suggests
*createmark nodes 1 "equal to value" inputsystemid $sysID
=> reference system
*createmark nodes 1 "equal to value" outputsystemid $sysID
=> displacement system
19 hours ago, Vikas Kumar said:
Thanks livil,
*clearmarkall 1
    hm_redraw
    *resetreview
Best Regards,
Vikas Kumar
And tinh,
How we can review like this. as shown in image.
