eschlieper
SparkFun RedBoard
I'm wondering if anybody has had any luck getting the SparkFun RedBoard to work with the Embed product?  I've been able to successfully compile and download to an Arduino Uno that I have but have not been able to download to the RedBoard.  I get an error: Can't open Com0.  Check that the Serial Monitor is closed.  I'm trying to use the blinking light test for both of these.  Any insight would be appreciated.
Erich
Dear Erich,
Could you please post in the issue that you see as a snapshot ?
Could you also double click on the Target Config block and let us know if the auto detect utility recognizes the redboard and the corresponding comport ?
Thanks,
--sreeram
Ok, I've had a chance to sit down and find the things you were asking for.  In case there was something with the FTDI driver creating the COM port, I updated that and still get the same issue.
It does appear that the redboard is not being auto detected.  I don't see anything in the COM port selection when editing the Arduino Config..
Attached is a picture of what I see there and the screen shot of the COM0 dialog.  I hope that helps.  I'm happy to show you anything else you need to see as well.
1045271177_COM0Message.JPG.56aa2bdcc763226a7eccbc3acffff318.JPG1453547569_ArduinoConfig.JPG.7d95c346a58c8ebfd3362b0b62664474.JPG
As a workaround please follow the below steps and I hope you should be able to get the hex file downloaded from Embed on the redboard that you have.
1) Navigate to the directory where Embed is installed. The default location is C:\Altair\Embed2019\cg
2)  Look for a file called downloadToArduino.bat and back up and make a copy so that you can revert in case there are issues modifying it.
3) Open the above batch file in a text editor like notepad and in line number 3 you would see
     set COMNUM=%2
4) Edit the above line to replace %2 with the comport number of your board for example if your redboard comport number is COM12 then
     set COMNUM=12
5) Save the file and now when you generate code from Embed and then try to download the hex file you should be able to get the hex file onto the target.
Please let me know if you need further help with this
--sreeram
Thank you Sreeram,
I'll give that a try and see if it works.  I'm going to assume then that if I've been using another board that wasn't having this issue that I'll have to switch between the two files or COM ports to when I move between the two boards.  That is manageable for me, I just wanted to make sure that is what needs to happen.
Erich
Hi Sreeram,
I tried the fix you suggested and it did not fix the issue.  I still get the Can't Open COM0 error popup.  I'm happy to try something else you think might do the trick.
Erich
