mansin
How to mesh lines automatically by using tcl script?
Hi ,
I wanted to mesh a lot of lines with variable lengths in model by using tcl script, but I found the sample script in help is not intelligent, for example
*createmark lines 1 15 18
*linemesh_preparedata lines 1 30
*linemesh_saveparameters 0 3 0 0
*linemesh_saveparameters 1 2 0 0
*linemesh_savedata1 1 5 0 0
The parameter "density" in line 3 and 4 are manually assigned, and the "segment" and "density" parameteres must be strictly matched. If the length of each line are different, the density are also different. So, a lot of *linemesh_saveparameters commands are needed. It is not acceptable for this meshing scripting.
So, is there a way to mesh lines with constant element size?
If the standard command is not suitable for you, write yourself!
Here's my script:
set elem_size 5;
set elem_type 61;
*createmarkpanel lines 1 "Select Lines"
set lines [hm_getmark lines 1]
*linemesh_preparedata1 lines 1 0 $elem_type;
set i 0;
foreach line_id $lines {
	set len [hm_linelength $line_id]
	set num [expr int($len / $elem_size)]
	*linemesh_saveparameters $i $num 0 0;
	incr i;
*linemesh_savedata1 1 $elem_type 0 0;
*clearmark lines 1;
Here's my script:
set elem_size 5;
set elem_type 61;
set i 0;
	incr i;
*clearmark lines 1;
when i am run this file their is error unknown entity type found what is this ?  what is element type 61?
