Hello All,
I have been trying to build a full model which flex bodies, contacts included but when I assigned a flex body to rigid body , contacts are no longer available. Is there any specific contact type that I have to use for flex bodies ? and the other question is my material will be rubber and I want to examine how those components assigned flex body distorted ? Can I examine that kind of solution via MotionView ?
Thanks in advance :)
Hi Abdullabh-
To answer your second question, the math behind flexbodies is based off of linear deflection, and linear material properties.  You will not get good results attempting to model a rubber component as a flexbody.  If you need to model something like a rubber component, you should investigate using the non-linear finite element feature in MotionSolve (NLFE).
For your first question:  MotionSolve does not currently support 3D contact with flexbodies today.   There is a workaround to this, where you attach many small rigid bodies to your flexible body with fixed joints.  These small rigid bodies can then be used with 3D contact.
Expanding upon @Chris Coker suggestions: NLFE bodies in Motionsolve currently support only 1D BEAM12 elements for Hyperelastic materials (Neo-Hookean, Mooney Rivlin and Yeoh).
Absolute Nodal Coordinate Formulation.pdf
Highly nonlinear models can be solved by an explicit method (Radioss):
-geometry (large displacements, rotations, buckling)
-material (hyperelasticity, plasticity and rupture)
-contact (sliding, friction, open/close status)
Abdullah Bozkurt likes this
Sign in to follow this
