Sign in to follow this
Mateusz L
Frequency response analysis - settings
Hello, I am writing to ask how correctly set FRA analysis?
I've made an example with simple plate:
1.Modal analysis:
2. FRA analysis:
- frequency function like that (just for example)
- base excitation - acceleration
3. Result:
Result isn't the same as in modal analysis as I supposed to. I expected peak values in 26Hz, 116Hz, 169Hz where resonace will occur.
Somewhere I made a mistake, can anyone help me?
Hello, I have quite the same problem, using Base excitation (Simsolid latest release 2019.4.1).
Just considering a simple input (constant acceleration 1m/sec^2) I can't obtain the same results between FEM analysis and Simsolid. Simsolid seems to convert and use the input acceleration in the wrong way respect to traditional FEM.
Frequency-function.JPG.24fb1b50d43931444ea8fc5b5f7e5423.JPGBase-Excitation.JPG.6aa7cb9795e2b74f51a2658f67bab7f6.JPG
Does anyone have already check the right correlation between Simsolid and FEM results in frf acceleration vs freq analysis (Base excitation)?
