Sign in to follow this
a.sharif122
*** ERROR # 1000 *** in the input data
I have tried to run numerous simulations for a car spoiler support, however i keep receiving the following error message:
 **                          OptiStruct 14.0                           **
 **                  Design and Optimization Software                  **
 **                   from Altair Engineering, Inc.                    **
 **        Windows 8 Workstation  (Build 9200)  CLN-TS-LIB1-256        **
 **          8 CPU:  Intel(R) Core(TM) i7-4770S CPU @ 3.10GHz          **
 **                        CPU speed  3100 MHz                         **
 **                    9991 MB RAM,  18724 MB swap                     **
 ** Build tag: 0801293aw733140_Ce64RBW8UH12M:111035-000  4000000004000 **
 **  COPYRIGHT (C) 1996-2015                 Altair Engineering, Inc.  **
 ** All Rights Reserved.  Copyright notice does not imply publication. **
 **         Contains trade secrets of Altair Engineering, Inc.         **
 ** Decompilation or disassembly of this software strictly prohibited. **
 *** OptiStruct defaults set from:
   install config file: C:\Program Files\Altair\14.0\/hwsolvers/optistruct.cfg.
 NOTE # 9199
 MSGLMT=STRICT is active, all messages will be printed.
 You can suppress some less important warning messages by use of
  MSGLMT=BRIEF or UNREF (in config file or in the input data).
 *** See next message about line 93695 from file:
     //sfs1.qm.ds.qmul.ac.uk/H2/Documents/newtpop/topology optmization work/support2502run
  "PSOLID         1       0"
 This line was interpreted as:
 93695:PSOLID, 1, 0
 *** ERROR # 1000 *** in the input data:
 Incorrect data in field # 3.
  Expected INT > 0, found  INTEGER (0).
COMPUTE TIME INFORMATION
 EXECUTION STARTED                         Mon Mar 25 13:32:59 2019
 EXECUTION COMPLETED                       Mon Mar 25 13:32:59 2019
 ELAPSED TIME                                         00:00:00
 CPU TIME                                             00:00:00
 *** PROGRAM STOPPED: FATAL ERROR(s) ENCOUNTERED.
                        ***** END OF REPORT *****
 For Useful OptiStruct Tips and Tricks, go to the URL:
 http://www.altairhyperworks.com/tips.aspx
 A fatal error has been detected during input processing:
   "PSOLID         1       0"
 ==== End of solver screen output ====
 ==== Job completed ====
Any help to get my simulations running would be greatly appreciated.
carsupport.hm
support 1.stp
