Sign in to follow this
alte1500
Error running Laminate optimization
Use Tools>Model Checker>Optistruct to find modeling errors.
https://insider.altairhyperworks.com/wp-content/uploads/2017/09/T-T-1248-HyperMesh-Model-Checker.pdf
In your model there are modeling errors:
-no thickness was defined in the non-design property
-material UD-1200 had E2=0 however UD plies have some transverse stiffness http://www.performance-composites.com/carbonfibre/mechanicalproperties_2.asp
-no Poisson's ratio was assigned on material BIAX-300-590
Construction was not connected to plating, so I have defined TIE contact using tools>contact browser>AutoContact
https://altairhyperworks.com/pdfs/tips/1095.pdf
The loads and boundary condition are incorrectly set up. The model should be properly constrained to prevent rigid body modes and unreasonable deformations.
I have undefined the SPC in the load step and set up inertial relief (PARAM>INREL>-2) instead, but the deformation is still unreasonable. Check the relevant literature on how such problems are constrained. The other model attached is constrained in all DOFs (encastre).
mesh_laminated_edit_encastre.fem
mesh_laminated_edit_inertia_relief.fem
Once all these issues are resolved in the baseline model, you will be able to run optimization:
alte1500 likes this
