mansin
How to properly set the G parameter in GRAV bulk data entry?
I have been confused by the parameter G in GRAV bulk data entry. I think this parameter is the acceleration of gravity. If I use the unit system of “kg, N, mm, MPa”, Should the parameter G be set to 9810 ? I found that If I set  G to 9810, the displacement of the structure in the case of gravity  is too large.
Gravity.hm
