Sign in to follow this
Ganesh Munge
how to check effect to temp on deformation and contact pressure in an object
Dear All,
I'm using HM as a pre-processor and optistuct as a solver. want to simulate following condition
shaft of size =10.000 mm and housing = 9.999 mm(interference of 1 micron) when i'm trying to rotate shaft using motor by keeping fixed housing. 150 degree temp is generated. want to observe the effect of temp on contact pressure and deformation of housing ID and Shaft OD.
model is setup is done as per NLQS. what extra i need to incorporate to observe above effect
regards,
Ganesh
