iwinphilip
Optimizing a spanner/wrench in hyper mesh-optistruct
I am a new user to Hypermesh, I am wondering if it is possible to optimize a spanner/wrench in hypermesh software (optistruct) and what would the constraints look like or how to apply one (normally there are no constraints acting on a spanner). I have attached the file along with this post.
Any valuable feedback would be welcome.
thanks
spanner1.hm
Hi iwinphilip
It depends on the type of optimization you need to perform. For optimization you need to organize the geometry in to design and non-design space. The non-design space resembles the constraining area where no design changes takes place.
Have a look at the e-book about Optimization in which it is explained in detail. ( https://altairuniversity.com/free-ebooks-2/free-ebook-practical-aspects-of-structural-optimization-a-study-guide/)
Also refer OptiStruct online help where you will get tutorials on optimization.
I tried optimizing but i am getting an error
*** ERROR # 2150 ***
 Invalid Volume or Mass Constraint.
 The response type is the total VOLUME.
 the upper bound value = 2.6100e+006
      the total volume = 8.7003e+006
     the design volume = 5.1900e+006
        the total mass = 6.5252e-002
       the design mass = 3.8925e-002
 The design material fraction (percent) should be at least 3 times
 the DOPTPRM MINDENS (default 0.01).
Could someone help me solve this error.
this error is due to an invalid total volume constraint.
Quote
The non-design volume is 3.513e+006, which is more than the upper bound value of 2.6100e+006, resulting in a negative volume of -0.903e+006 available for optimization.
Using mass or volume fraction will ensure valid positive mass/volume formulation.
The model you have shared had some issues. I have remeshed the part and scaled it to 1/10th the size, which I think is more consistent with the loading and material units.
spanner2_edit.hm
iwinphilip likes this
glad to help. The steps are:
Geometry:
  • Geom>autocleanup
  • F11 (quick edit geometry) for manual defeaturing used toggle edge, replace point and add/remove point
  • Geom>solid edit>trim with lines>with bounding lines for partitioning
  • Tools>scale>uniform
Meshing:
  • F12 (automesh)>QI  optimize>trias + meshing criteria
  • 3D>tetramesh>Tetra mesh>Float trias/quads to tetra mesh
  • F2 delete the shell elements on solid faces (use mask panel or browser to isolate only 2D elements)
  • F10 check elements>3D
  • inspect how the mesh conforms to geometry. Use shift+F7 to project nodes to geometry
  • shift+F11 to organize elements into design/non-design components
  • 1D>rigids to create rigid spiders
Load step:
  • constrain master node of a rigid spider on one end with Analysis>constraints
  • define load on master node of a rigid spider on the other end with Analysis>forces in a separate load collector
  • reference appropriately the two load collectors under SPC and load in Loadstep definition
spanner2_edit.hm
spanner2_edit.fem
You're welcome. There are some great learning materials from Altair university- Practical Aspects of Finite Element Simulation is a good starting point.
Check the following Youtube channels:
Altair University
Altair India Student Contest
ELEATION By Apoorv Bapat
how did you edit the volume of the model by using scale (1/10th) depending on load and force.
Could you provide the steps and whether this has to be done at the very beginning or later stage.
Thanks
by using Tool>Scale>uniform
Tips:
  • you can find various functionalities with ctrl+f then type in the keyword(upper right corner)
  • F1 or H for help while working in any panel
1/10th scale was arbitrarily chosen. Make sure to scale according to your data. Note the model units consistency is N, mm, tonne, MPa.
Scaling can be done at any stages, but it is a good practice to get the geometry right from the start to avoid confusion.
Hi Ivan
I created another model and tried to run  but when i run i still get the same error. (all units are in  N, mm, tonne, MPa.)
 the upper bound value = 3.6295e+004
      the total volume = 1.2098e+005
     the design volume = 8.6894e+004
        the total mass = 9.0737e-004
       the design mass = 6.5171e-004
So I did calculate manually Non-Design Value =  the total volume -  the design volume
        =   1.2098e+005 - 8.6894e+004 = 34086 which is less than the the upper bound value = 3.6295e+004.
 Formulation for volume fraction:
Volume fraction = (total volume at current iteration – initial non-design volume)/initial design volume
I took 30% of volume as upper bound
Volume fraction = (3.6295e+004 - 34086)/1.2098e+005 = 0.01825
Could you correct me if i am wrong in my calculation with an example and point out where I had made the mistake and if such mistake occurs in the future how to resolve the issue.
I have attached the model  along with this file. Kindly let me know if I have done any other mistakes.
please note this is what I considered
moment = 50000n/mm
length = 240mm
force = moment/length
force = 208N
Kind Iwin Philip
Iwin2.fem
Iwin2.iges
Sapnner2.hm
Even though the volume available for optimization is positive, it is still below
Quote
The design material fraction (percent) should be at least 3 times the DOPTPRM MINDENS (default 0.01).
MINDENS= Sets a lower limit on the amount of material that can be assigned to any design element. Extremely low values for this parameter can result in an ill-conditioned stiffness matrix.
(upper bound volume - non-design volume) / design volume > 3 x MINDENS
(3.6295e+004 - 34086) / 8.6894e+004 0.025 < 0.03
Slightly increasing the upper bound volume or decreasing the MINDENS parameter (analysis>optimization>opticontrol) should work.
iwin_edit.fem
Hi Ivan,
Thanks, Now I understood how the volume optimization works. I tried out and i get the result all the parameters have been satisfied but when I look at the iterations its all the same. I have attached a photo of it and also the file named "spanner1". Could you let me know why i don't get an optimized model.
spanner1.hm
Solid>Bounding Surfaces cannot be executed, because the solid is already created.
Verify by going to Geom>solid edit panel and picking the solid. Also when in edit geometry mode (for example in the F11 quick edit panel) surface edges of solid objects are slightly thicker than surface edges not enclosing solid objects.
Thanks for that. Could you please help me out with how to do FEM analysis for this model. (the steps involved in this process)
Kind Regards
Iwin Philip
Like mentioned before, I suggest you start with Free eBook: Practical Aspects of Finite Element Simulation (a Study Guide)
Check these Youtube channels:
Altair University
These tutorials might help:
https://altairuniversity.com/learning-library/linear-static-analysis-tutorial-of-a-bracket/
https://connect.altair.com/CP/SA/training/self_paced/os_linear/content/linear_1/PDF/1a_doit.pdf
https://altairuniversity.com/wp-content/uploads/2012/05/Tutorial_BasicFEA_AcademicBlog.pdf
First try to do it yourself and ask for help if you fail.
Thanks a lot . I will have a look. But i did try out many forces and other possibilities but still not getting a model like what i wanted to as shown in the picture. the only result i am getting is the model without the red lines which i think is wrong. any valuable feedback/suggestions appreciated.
Kind Regards
sample.hm
