I have a structure made of 3d solid map hex mesh elements, ie. primitive unit cells (see primitive image attached). I have turned my hex mesh elements into bar2 elements. I would like to create a central node to the primitive unit cell and connect bar elements to this central node (see body centred cubic image). I know this will most likely be a TCL script problem but I'm not sure how the script would be written.
I have successfully created the primitive unit cell and used config edit tool to create bar2 elements (CBEAM's) But I would now like to do this with elements connected to a central node.
A comparison of what I'm attempting to do can be seen in this paper: https://www.ncbi.nlm.nih.gov/pmc/articles/PMC6265793/pdf/materials-11-02073.pdf
I look forward to hearing from the community,
Kind Regards,
Laurence
I have a structure made of 3d solid map hex mesh elements, ie. primitive unit cells (see image attached). I have turned my hex mesh elements into bar2 elements. I would like to create a central node to the primitive unit cell and connect bar elements to this central node (see image attached). I know this will most likely be a TCL script problem but I'm not sure how the script would be written.
Kind Regards,
Laurence
On 4/15/2019 at 8:06 AM, Imoto said:
Hello @LFM1995
You can use *createbestcirclecenternode API.
Example:
*createmarkpanel nodes 1 "Select nodes";
*createbestcirclecenternode nodes 1 0 1 0;
Thanks,
Imoto
Hi Imoto,
Yes, this allows me to create a center node, which is part of the solution. How do I now create a central node for each quad element, as well as creating lines that connect to this central node from all 8 edges?
Thanks,
Laurence
inputfile.hm
Hello @LFM1995
If you still have the hexa elements, please try this.
hm_entityrecorder elems on;
*createmark elems 1 "by config" 208;
foreach elemid [hm_getmark elems 1] {
 lassign [hm_entityinfo centroid elems $elemid] X Y Z;
 *createnode $X $Y $Z;
 set center [hm_latestentityid nodes];
 foreach nodeid [hm_getvalue elems id=$elemid dataname=nodes] {
  *createlist nodes 1 $center $nodeid;
  *createelement 2 1 1 1;
hm_entityrecorder elems off;
set newplot [hm_entityrecorder elems ids];
if {[llength $newplot] != "0"} {
 hm_createmark elems 1 $newplot;
 *configedit 1 "bar2";
hm_markclearall 1;
Download --->>> CreateBeamForCentroidHexElements.tcl
LFM1995 and Pandurang like this
On 7/28/2020 at 1:49 PM, Vlad VB said:
can you share the script? I can't find it. Thank you
Sorry, i remember that i wrote it in a post but for a long time...
