Matteo95
Optimization Run Problems - Altair Inspire
Every time I try to run a topological optimization with Altair Inspire I have the same problem: the optimization seems done at 100%, while the software does not allow me to view the results because the run status is still running (picture). What is the problem?
I am using the student version of the software.
Thank you
I have this same issue with Inspire 2019. (those pics should be in the opposite order; aka, red x after the green '100%' status bar).
Additionally, all analyses freeze at 64% and never complete. They eventually show up with a red x, as a failure.
This happens with models I have created, and with those that I've dragged and dropped from the Inspire webinar course file folder "INSPIRE for Structural Analysis and Optimization -V2019"
Exercise_1.stmod
I have exact the same problem and i already got the 2019.0.1 EDU version of Inspire.
It seems to be a problem of Inspire 2019 in combination with a specific Hardware configiration.
By the way, in version 2017.1 the same model runs perfectly.
I am optimizing on the following computer:
Windows 10 Professional version 1903
Intel Core i5 8600K @ 3,6GHz
Zotac RTX2070
16 GB DDR4 RAM @ 2666 Hz
everything is saved on a 500GB Samsung SSD 860 Evo
I am able to run shared .stmod file with Inspire 2019.1 with slight modification.Is this happening for all Inspire optimization & analysis runs?
If possible please share the license file you are using.
I have the exact same issue on 2019.0.1 EDU.
My username is "FIRSTNAME LASTNAME". Does the space count as a special character? Regardless, changing my username is not really a solution as making that change would require me changing login accounts and everything on my PC.
Is there a solution to this issue??
Thanks.
Has this problem been solved by anyone? I am having it as well, after downloading Inspire today. I have a student license and have been trying to run through an Altair optimization tutorial with a pre-loaded part. Need this program for multiple projects, so I would love to find a solution. Thanks
we enhanced Altair INSPIRE to address the issues in this thread. You can download and install INSPIRE 2019.4 to check your reported models on the same hardware as you used to. Please inform us, if the error still occurs.
Altair Inspire 2019.4 can be downloaded from https://connect.altair.com - please use a university mail address to register on this customer portal (no gmail etc. can be approved).
Jan
I have the same problem (still running at 100%) and I tried using 2019.4 but it did not change anything. I have student license.
At first I thought it is insufficient computational power (RAM, CPU etc. )problem so I made design space a small section and made target mass to 99%. It reached 100% completed in 10 minutes but I waited 12 hours after that and it did not finish. So it looks like it completed the job but it cannot display it. I dont have any idea what is the problem. I am planning to take a blind shots to solve the problem:
-use different version (2017.1 maybe)
-use different computer (can we use the same license on another computer?)
-change the imported file type (I import the files from Solidworks in .sldprt format maybe change to .step)
Is there anyone that could solve the problem?
