Sign in to follow this
help on macro(FREE EDGES- T-CONNECTIONS)
hi,
i am running the below list of process through macro to create free edges and t connections in a single click for displayed elements,
The limitations of this is every time I need to delete the components named "ed" and "^edges" beforre running this macro,
Is it possible to make the macro itself check for those collectors and remove them each time macro is executed.
*createmark(elements,1) "displayed"
*findedges(elements,1,0)
*renamecollector(components,"^edges","ed")
*findedges(elements,1,1)
*createmark(components,1) "^edges"
*colormark(components,1,6)
*displaycollectorwithfilter(components,"none","",1,0)
*displaycollectorwithfilter(components,"on","ed",1,0)
*displaycollectorwithfilter(components,"on","^edges",1,0)
hope someone will help,
check this
catch { *createmark comps 1 "ed" "^edges"}
catch { *deletemark comps 1 }
*createmark elements 1 all
if { [ hm_marklength elems 1 ] > 0 } {
*findedges elements 1 0
*renamecollector components "^edges" "ed"
} else {
tk_messageBox -message "No Elememts "
return
*findedges elements 1 1
*createmark components 1 "^edges"
*colormark components 1 6
*displaycollectorwithfilter components "none" "" 1 0
*displaycollectorwithfilter components "on" "ed" 1 0
*displaycollectorwithfilter components "on" "^edges" 1 0
hi,
:d/ :d/ :d/ :d/
thank you for your reply.......
i have executed it through the command window, it has 2 problems,
1. First error occurs only for the first time of executing the algroithm
it says components have not been selected, but continues further
2. I couldnt make out why this is happening, after the free edges are displayed, we need to click the enter key in the command window to get the T connections displayed.
looking forward for your reply,
I guess below lines should work to delete
set del_comp_list "^edges ed ";
eval *createmark components 1 $del_comp_list;
*deletemark components 1;
