young
Preloading using nonlinear results for frequency response
Hello everyone,
I would like to ask for an advice in solving a frequency response problem on a preloaded structure.
I create two load cases in a single job.
The first load case selects nonlinear Quasi-Static (NLSTAT)
the second load case selects freq.resp(direct) ,for substate(preload) ,select the first loadstep.
set  PARAM,LGDISP,1
Unfortunately,the solver gives an error:
 *** ERROR # 4754 ***
 STATSUB(PRELOAD) of subcase 2 points to a nonlinear subcase with large displacement, which is not supported.
Best regards,
young
On 4/22/2019 at 2:20 PM, Rahul R said:
Preloading with Large Displacement Nonlinear Analysis is supported from HyperWorks Solvers 2017.2.2 and above version.PFA deck and refer release notes from online help.
53_Disk_LGDISP_Support_wPRELOAD.fem
Thank you for your answer,it is working when i use HyperWorks Solver is 2017.3.
Rahul R likes this
