alte1500
Inspire Closes when starting Analysis
I've trouble analyzing my inspire construction. After setting up my contacts, forces and constraints I'm starting the analysis and then inspire crashes and closes itself. Very strange because i've done several analysis's and optimizations before without experiencing any troubles. Also have I done several analysis's with this same particular model, only the constrains have changes slightly.
Does anyone know the answer to my problem?
I have already found the solution. Apparently made the slight modification my model just too large to solve.
So if anyone experiences the same problem, keep this in mind ;)
