cemreyvz 0 Report post Posted April 17 Hello, As I try to do Hyperstudy setup for parametrized model, after the nominal run. The out file is created and I can see the stress results there but as I want to create an output response, The responses can not be read by hyperstudy results reader from the out file in approaches>m1> run01 only text extraction appears. What can be the problem? Thank you Quote Share this post Link to post Share on other sites
cemreyvz 0 Report post Posted April 18 Can anyone please help me?? Thank you Quote Share this post Link to post Share on other sites
