Alex.01
Problem with Hyperview
Hi all,
I usually have a session saved with all the contour and legend options set. When I open the session in Hyperview, I can see that in the most cases the plot is not updated. I don't know how to explain well, it is as if Hyperview doesn't apply the contour and legend options in a correct form. When this happens, I have to do an extra task, which is (you can see in the image I attach):
   - Select the component displayed
   - Apply the contour options
I don't have to set any option (because all options are set already when I open the session), I only have to do the two options I describe. But if I have many windows in Hyperview, I waste a lot of time doing this.
Does anyone know why this happens or how can I solve the problem? Maybe there is a way to do a tcl script which can do these actions?
Thanks in advance,
Alex
Hi Alex,
You can trying saving the session as a Template file. (File>Save As>ReportTemplate)
After that open the Template file. (File>Open>ReportTemplate)
Livil
