Hi Acusolve users,
I have a problem related to bathroom shower where I need to see the flow distribution.
I need suggestions on the methodology to be applied. I am thinking to create a cylinder as shown in figure(second one) to capture the flows. But will it be possible to do in acusolve as it will be a case of multiphase flow.(Water+ atm. air).
Any suggestions to achieve a correct methodology ?
image.png.ab9c9af0876c78cdfe98e3e0592de756.pngimage.png.9207bb4c70bc27fe8c59928fbba8c93d.png
The flow from  a shower is probably better solved with NanoFluidX than with AcuSolve. AcuSolve is an Eulerian code and in my opinion, a particle based code is better suited for this application.
Thank you for the reply.
I am sorry but any scope in Acusolve for solving such cases. I will be interested to understand the pressure drops in each holes in the shower rather than on particle movements currently.
